- 6 Aug 2013
hello all
I have a xigmatek elysium case and I currently use the top rad space for my closed cpu cooling H110 (soon to be H320) I want to fit 2x H110 in this case one each for my dual gpu and i was hoping for ideas on how to fit them ,, hopefully with out modding my case much if at all (as im not the experienced at that sort of thing)
my power supply is fitted at the bottom to allowed for the large rad that is fitted at the top.
one idea i had (please say if this is to crazy or just simply not going to work ) is to for both sandwiched together in push pull push pull at the front of vertically in the drive bay area as intakes , ie fans, rad, fans, rad fans.(rads are 280mm)
I realize that the second rad would get warmer air as it as gone through the first rad , but iv read that the difference might be less than a degree, if anything , especially as it is set as intake ?
please tell me what you people thing and any ideas you have.
p.s im not sure i can fit one one the bottom next to the power supply and one in the drive bays , i have one cdrom and 2 ssd's and 1 hhd in the drive bays also.
thx for any help or info.
