Some help please
24 Aug 2011
Hi.
I'm having some problems with my network or whatever it is. Yesterday i reset my overclockers password and as soon as i did the overclockers website gave me a 404 error. I thought the site went down but as the day went on i still couldn't get back on. At the moment im using a VPN to write this.
I've tried several things with CMD / cleared cache / ccleaner / cookies
But im still unable to access this site unless i use a VPN :/
I've reset the router settings, reinstall Chrome but nothing works. Its only stopping me visiting overclockers and nothing else. Any ideas??
Thanks!
The only thing i have done in the last few days was using some cmd to fit my xbox app party chat.
netsh
int teredo
set state disabled
int ipv6
set teredo client
whatever that does? it fixed my xbox app problems but may have caused more?
Did you shut down your machine while logged into your vpn?
Try logging out of your vpn now and see if you can get internet.
When it’s not working then type IPCONFIG /ALL and post the results
Also when it is not working can you browse any other sites and can you browse https://185.103.4.11/ (ignore the SSL cert error if you get one)
I had a similar issue. I reset my password on this forum, then afterwards for a day or so I couldn't go to overclockers shop or forum, like my IP was blacklisted. I had to VPN to work to use the site.
