Some help pls
18 Aug 2010
Scotland
Sometime in late June I bought from Overclockers: Vengeance LPX 8GB (2x4GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK8GX4M2A2666, GA-AB350M-Gaming 3 and Ryzen 5 1500x.
The system was working great back then until yesterday when on booting up, there was no video.. So I did the normal checking with moving the ram around, switching graphic cards and finally trying out the parts that had been replaced by the above parts, with an Intel motherboard, cpu and ram. The problem was solved and so I gather that the one or more of the new parts is at fault, but I am curious as to which one? I will be calling Overclockers on Monday to see about sending back everything and hopefully getting back something that works as it should.
TY in advance for any help
You have given nowhere near enough info, and the info you have given is confusing. I don't see how you can possibly be helped with this amount of background??
I thought the info I had left was sufficient, but it seems I was wrong and I am sorry for that. Perhaps I should have written that the system would no longer post? I am not a tech and know very little about pc's, so a helpful reply was all I was looking for.
