- 12 Oct 2011
Hi
Just had to upgrade my motherboard. Have a q6600 CPU and as I am quite happy with this decided on the Gigabyte GA-G41m-combo. I did have the Asus P5KC.
On the Asus board the board controlled the speed of both the CPU fan and also the 2 case fans I have (front and rear). However the new board only controls the CPU fans speed and the single 3 pin case fan plug only powers it on full.
So I have been looking at alternatives. I have came across the idea of PWM fans. Now this is my question. It is my understand that if I replace both case fans with PWM fans and get a PWM connector cable I would then plug all 3 fans (case and CPU) into this cable, connect the cable to a mowlex connector for power and connect the 4 pin to the motherboard CPU connection.
Am I correct in this thinking?
Thanks for your help
