Some i5 4670k questions
26 Oct 2013
Leicester
Hey 8 Pack,
Firstly grats on all your WR on benchmarks etc.
Just wondering what you have found is the best batch of CPU's for the 4670k's, as I've heard that the Costa Rica batch is quite good for overclocking (as it turns out I have one :D ) Also, what would you say is a good voltage for a small 4.0ghz overclock? Using the system in my sig, I've seen varying opinions on good vcore (I'm a noob to overclocking). I was thinking of changing the Vcore to about 1.25 and the clock speed to 4000mhz of course?
Cheers
With a good chip 1.25 is 4.5 easy.
1.25 should on all chips do 4.0 yes.
As for what batch are good I dont know with 4670. They dont go in 8Pack systems are not as efficient as 4770K for benching due to less cache size so I have never focused on testing and ordering certain batches.
