Some illustrator help required
5 Jul 2005
Brighton
Just wondering if someone could do a little thing in Illustrator for me as the trial I have for some reason won't let me select the alternative tools (ellipse for example).
I need this .jpeg as a .AI file (just the case side panel in 2D):
In case you need them the measurements for it are 585mm x 445mm and grill is inset 45mm from the top and 37mm from the side.
A virtual cookie or two for whoever can do it for me ;)
I have done it now anyway in Photoshop, couldn't get to grips with Illustrator in the amount of time I had.
