Randomly removing packages when you are not sure what they are doing it probably a bad idea.
Googling for "gnm-sstm-mntr error (No such file or directory)" without the quotes gives the first hit from the Linux Mint forums for a thread with someone with the same issue and it looks like that there may be a mis-defined keyboard shortcut going by the end of the thread.
I would also be surprised if you were actually running a 64bit PAE kernel as normally you have 32bit PAE kernels to get over the 32bit memory limits which 64bit kernels don't have.
