Well, I have been cursing my e4300 at 3GHz thinking it was causing my fps drops in UT3 and ET:QW, but just earlier when I was running the COH bench, I noticed it was capped at 60FPS.
ET:QW doesn't seem to reach as high as 60, and is usually around the 45 FPS mark, which is low.
UT3 runs anywhere from 80 fps, down as low as in 20's, which is bloody awful.
Can't tell with Crysis, though it seems unaffected. FPS jsut a little lower than would have expected.
F.E.A.R seems unaffected, and runs into hundreds of FPS, but I have noticed some kind of hitching when it loads a scripted event
Now I double checked the vsync setting in CCC, and it was set to use application settings, and I double checked and it was not enabled in any games. I set it force no vsync but still same.
This is running catalyst 8.6 with hotfix.
Anyone got any suggestions? I jsut convinced myself today to keep the 4870 and upgrade cpu, but things like this are *** exact reason I wanted to get away form pc gaming
