Some mechanical help please celica front shock
22 May 2004
N.Ireland
Hi guys
Please bear with me as im not a mechanic :)
Have a problem with the front driverside spring. Car is lower on that side. This seems to have started when the car was jacked up to change the wheels as I was changing wheels to winter tyres.
I noticed it as the car goes to the right under heavy breaking. So I jacked it up and took the wheel off the other night to have a look, Spring seems intact but on the top of the spring is a plate and it will move if i poke it when the other side shock it is solid. So is this a broken spring or just the plate that holds the spring on has loosened?
Any advice would be great
Gareth
Called into local mechanic and he cant take it for 2 weeks. I use my car for work so will have a look this weekend and If i cant sort it will have to wait until mechanic has time.
