some more gigabyte P34W questions (Atom and Ryu)
16 Dec 2015
Hello Atom and Ryu,
I have some more questions about both P34W and X3 Plus laptop, any update news about the available date for Aorus X3-Plus-V5 and Gigabyte P34W-V5 series laptop on UK wide market?
I'm confused by the config of P34W-V5 from SCAN. That is a P34W-V5 CF2 config, however their CS told me it is equipped with 2560x1440 panel and 2TB HDD???? Is that true? Doesn't only CF1 will equip with 2560 panel?
Thank you
Hello Atom and Ryu,
Thank you
Hi david,
Firstly AORUS X3 v5 - we expect to be back and ready to ship from OcUK by next Tuesday :-)
P34W, here are the two versions:
Higher end unit has QHD IPS Sceen ( 2560x1440 )
https://www.overclockers.co.uk/giga...6gb-ddr4-gtx-970m-3gb-128gb-m2-lt-021-au.html
The other unit is identical in all other elements of the specification, apart from it has FHD IPS screen ( 1920 x 1080 )
https://www.overclockers.co.uk/giga...6gb-ddr4-gtx-970m-3gb-128gb-m2-lt-020-au.html
The CF2 which is available elsewhere has been mis-communicated to you.
Hope that clarifies for you.
Regards,
Atom80
