Some Mysql Query Help
13 Nov 2003
Manchester
Hi All
Does anyone have ideas why this query isnt working? It doesnt return any errors, but it doesnt effect any rows.
Code:
UPDATE in_price_comb_temp SET stock = 'in_stock_temp.stock', date_added = 'in_stock_temp.date_added' WHERE 'in_price_comb_temp.dist_pn' = 'in_stock_temp.dist_pn'
Not sure if this even should work. Just trying to find a way of not selecting all the records and updating them one by in PHP
Thanks
Aaron
Code:
UPDATE `in_price_comb_temp` P LEFT JOIN `in_stock_temp` S ON p.dist_pn=s.dist_pn
SET p.stock=s.stock, p.date_added=s.date_added WHERE p.dist_pn=s.dist_pn
Maybe? I'm rubbish at joins though :)
Code:
count (*) from in_price_comb_temp a where exists (select * from 'in_stock_temp' b
WHERE a.dist_pn = b.dist_pn)
You may need to format that a bit (I usually work with DB2), but it should return the number of rows to be effected by your SQL.
If you post what's in each of the tables, and what you're trying to do people might be bale to help. Posting random SQL statements won't help you poke holes in anything but the validity of your SQL syntax.
It's all about context!
Hi Jon
Thanks for the message. That query doesn't work :(
I can't give too much information on here, as its quite sensitive. I will give all the details I can, what would help?
Thanks
Aaron
