Some Nero Help please
8 Dec 2004
Paignton, Devon
Hi all, I have converted my home videos into DVD format with the Audio ts and video ts folders but the software im using seems to have a problem with then burning it to dvd, Can i just burn these files to dvd using nero? when i try to burn them in the DVD data mode it tells me that if i do it then it won't be readable in a standalone dvd player.
I have also tried using nero vision but that just wants to convert all the vobs into a single file.
Any idea's how i can get these folder onto a DVD so it can then playback in a standalone dvd player?
what format are the files in the folders? if they're VOB / IFO (dvd) then just use imgburn in build mode
To answer your Question, YES.
You do not need touch Nero Vision as your have the Vob's already so simply burn it in NERO as a DVD-Video not DVD-ROM ISO. ;)
