- 6 Jun 2008
hi
I am working on a new build and hoping you can help me understand power supplies better ...
-- question 1 --
psu efficiency is rated like "90% at 50% load"
which means efficiency will reduce as load increases ...
does this mean that running a 600w load through a 1200w psu
could be more much more efficient than a 600w load through a 600w psu ?
where is the sweet-spot?
-- question 2 --
can't find info about mobo and ddr3 power consumption ...
my estimates:
i7 930 @ 4.0 = 190w
gtx 460 = 170w
1 x ssd = 5w
2 x sata = 24w
asus p6x58d-e = ???
3 x 2gb ddr3 = ???
how do I work those out?
-- question 3 --
i will use this pc for work (as well as play) - it needs to be very reliable
otherwise i could lose income
that means I don't mind spending extra money if it increases reliability
which is the ultimate psu for reliability, and voltage protection etc.
at the moment I am thinking about:
Corsair Professional Series™ Gold AX850 High Performance 850W Power Supply
-- or --
Coolermaster Silent Pro Gold 1000W Power Supply
I know the 1000w is way higher than I need - but considering it might save me money in future and overall efficiency might be higher (700/1000 is closer to 50% load) - it could be a good idea
-- question 4 --
do power supplies draw current regardless of load?
because with transformers there is a high voltage circuit even when nothing is connected to the low voltage side ...
hope you can help me out
-- question 1 --
-- question 2 --
my estimates:
i7 930 @ 4.0 = 190w
gtx 460 = 170w
1 x ssd = 5w
2 x sata = 24w
asus p6x58d-e = ???
3 x 2gb ddr3 = ???
-- question 3 --
-- or --
-- question 4 --
