Ok i overclocked my E8500 to 3.8, however i got an error in prime after 10 mins
Settings were 400FSB, 1.28 volts, showing as 1.24.8 in cpu Z
ram at 1066
I decided to lower the clock to 3.6 using a FSB of 380, keeping voltage etc the same
Mem is now at 1143
Timmings 5-5-5-15
How long should i run the prime 95 test to be sure of a good stable overclock?, there are 3 differant tests in prime should i run all 3 for the same amount of time or can some be done quicker?
Just one more question to those who are overclocking there E- series what voltages are you using and what overclocks have you got?
ram at 1066
Mem is now at 1143
Timmings 5-5-5-15
