some problems!!(bsod)
5 Jun 2013
hello guys,
recently i am having a problems with my computer, unfortunately i did ccleaner and all dumb files were eliminated, but i did a backup with bluescreenview:p
also is randomly twice a day
i tried everything : vit registry fix, system file checker and many others
threres the bluescreenview results
Dump File : 052213-23031-01.dmp
Crash Time : 22-May-13 04:44
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 0x63637051
Parameter 2 : 0x00000002
Parameter 3 : 0x00000000
Parameter 4 : 0x888a19f5
Caused By Driver : tcpip.sys
Caused By Address : tcpip.sys+8a9f5
File Description : TCP/IP Driver
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Processor : 32-bit
Crash Address : ntoskrnl.exe+38b3b
Stack Address 1 : tcpip.sys+8a9f5
Stack Address 2 : tcpip.sys+8a7db
Stack Address 3 : tcpip.sys+8a4b0
Computer Name :
Full Path : C:\Windows\Minidump\052213-23031-01.dmp
Processors Count : 2
Major Version : 15
Minor Version : 7600
Dump File Size : 142,736
Dump File : 052213-20296-01.dmp
Crash Time : 22-May-13 04:45
Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000008e
Parameter 1 : 0xc0000005
Parameter 2 : 0x00000000
Parameter 3 : 0x8ffc7afc
Parameter 4 : 0x00000000
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : 32-bit
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052213-20296-01.dmp
Major Version : 15
Dump File : 052013-19625-01.dmp
Crash Time : 20-May-13 05:45
Bug Check String : UNEXPECTED_KERNEL_MODE_TRAP
Bug Check Code : 0x0000007f
Parameter 1 : 0x0000000d
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+3927b
File Description : NT Kernel & System
File Version : 6.1.7600.17273 (win7_gdr.130318-1532)
Processor : 32-bit
Crash Address : ntoskrnl.exe+3927b
Stack Address 1 : ntoskrnl.exe+1fdf17
Stack Address 2 : ntoskrnl.exe+b4e15
Stack Address 3 : ntoskrnl.exe+b4e05
Computer Name :
Full Path : C:\Windows\Minidump\052013-19625-01.dmp
Major Version : 15
thank you for any help
megahackerd
(sorry for my bad english)
Tcpip.sys crashes can be caused by a corrupted application on your system sending junk to the network driver. The mini dump file may help to pinpoint which application is the culprit.
the virgin media give me the usb wireless adapter, and it got the latest driver.
wnda3200 the name for the model.
thanks for the quick reply
On looking this up on Microsoft forums, it is most commonly caused by anti-virus software.
i am using mse from Microsoft ( i tried to install avg (paid one) and give a fail- i only tried to install because i was detecting 5 trojan horses per minute, but i couldn't, after i tried to re-install and everything went well, also i used the avg removal tool for take the fail out
i got a new one here:
Dump File : 061113-27578-01.dmp
Crash Time : 11-Jun-13 04:52
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x00000000
Parameter 2 : 0x000000ff
Parameter 3 : 0x00000001
Parameter 4 : 0x82c9b32d
Caused By Driver : Unknown_Module_ffffffff
Caused By Address : Unknown_Module_ffffffff+0
File Description :
Product Name :
Company :
File Version :
Processor : 32-bit
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061113-27578-01.dmp
Major Version : 15
Dump File Size : 131,072
heres the dumfile:
https://www.dropbox.com/s/l2vvvhi0cev3gzj/061113-27578-01.rar
