Some PSU advice required
25 Sep 2017
Essex
Hi all.
My current setup in sig is powered by a 550w and just wondered if that's enough?
Just to clarify, 7700k - Z270E Mobo - Strix 1080 - Kraken X62 AIO - 16gb GSkill 3200Mhz RGB Ram - 2 x 2tb 3.5" HDD - 1 x 120gb SSD - 2 x 140mm fans - 6 x 120mm LED Fans - 60cm RGB light strip
PC Part picker rates my power draw at roughly 410w so i'm guessing this is OK but would like a second opinion.
If i were to upgrade the PSU im looking at an EVGA Supernova 750 G2L - Any good?
What make and model is it? If it's a decent one then 550w is more than enough for your pc. To give you a idea of power draw the pc in my siggy along with several fans, temp sensors, 2x fan controllers and all the watercooling stuff hit a max of just under 300w at the wall when benching with the gpu heavily overclocked. This is with the cpu and memory overclocked as well. Normal gaming use is 122-252w at the wall depending on the game.
