edit: oops theres a specific overclocking board
 move please? Sorry I don't know how i missed it
I havn't done a lot of searching because I want some good personalised advice and I know people here dish it out in rivers. I recently build a system for a friend and my intention is to get a nice overclock on his q9550, here is all the system information:
case: NZXT m59
mobo: DFI Lanparty DK-T2RS Plus
cpu: core 2 quad 9550 E0 SLBV8 batch: L930B834 MM: 899133
hsf: ac freezer 7 pro v2
ram: 2x2GB Corsair XMS2 1066MHz
psu: OCZ ModXtreme 600W
gpu: 7900gs (getting ati 5xxx or nvidia 3xx later)
hdd: samsung spinpoint f3 500GB
I have the cpu at a nice 3.2GHz but trying to get it to 3.4 pretty much results in prime 95 not responding - as windows puts it (nope, not worker thread stopped).
The VID of this chip is 1.3 which seems a tad high to me (core temp told me, can I trust it?)
Firstly, I have the RAM dialed back to 800MHz with the fsb at 353. and the multiplier at 8.5, cpu voltage can sit around 1.25 and seemingly be stable and run at load max temp 51C. Other voltages at deafault/auto.
Now, the bios seems to be version 6.00 - but I have no idea how recent that is, the ones on the site are only given by date and the update process is annoying: I need a floppy drive or windows xp to do so - the system is running windows 7. I tried boot from usb but I can't ever get that working, when I download the dos files and extract them the path becomes 'dos/dos/[content]' now, I presume I format it with the HP tool choosing the 2nd folder (dos/dos) - but incase that is wrong I shall slap myself later, and possibly whoever is responsible for making the bad zip archive too
Even if I get a floppy drive I then need to get a floppy disk :O
But anyway: I know the board is excellent for the fsb - but what voltages should I expect the cpu to require? And as I raise the fsb and cpu voltage - and NB voltage when appropriate. Do I tweak other voltages too? With my p5n-t deluxe I had to change the "1.2v voltage" to 1.25 - after investigation it turned out that was the voltage of a bus somewhere.
Now I hear the 9550 is generally safe under 1.4V, so I don't want it to go above 1.35V for long term use - even if the temps would permit a higher overclock, with proper adjustment of bios settings should I be able to attain 3.4 or maby higher? I got my q6600 to 3.8GHz on my nForce board - just didn't leave it there because I want the chip to last.
 move please? Sorry I don't know how i missed itI havn't done a lot of searching because I want some good personalised advice and I know people here dish it out in rivers. I recently build a system for a friend and my intention is to get a nice overclock on his q9550, here is all the system information:
case: NZXT m59
 the batch VID is 1.3 I am almost certain because it needs a fair bit of vcore to get OCs going. for 3.4 I have it at 1.36 under load and it backs down to 1.12 when whatever that energy saving thing is called drops the multiplier for me. the system is away with its owner now though. but I can still get to it if I want to have a play with settings, ive got all the setttings written down so I cant really mess it up.
