Some questions about multi-core and multi-thread...
30 Mar 2013
I have a questions.
Suppose suddenly every games became 8 core supported...which will perform better then?
Intel core i7 or Amd fx-8350?
Please answer geeks...
......depends........
i7 - higher IPC 4 real cores and 4 virtual cores.
FX8350 - 8 real integer cores with shared floating point module 1 x 256bit per module or 1 x 128bit instruction per integer core.
.........largely on coding of the application threads, but the i7 will edge the 8350 at the moment at a price................
So do you recommend buying an i7 instead of fx-8350?
I need a future proof pc,i mean i will use it for about 4 years...
Moving further up the i7 range the 3930K widens the gap. Six physical cores + six virtual with hyperthreading enabled.
AMD does have some interesting upcoming products though. Steamroller looks promising, and with their dominance in next-gen consoles things may begin to turn around for them.
Anyway, that's enough excitement for one day tahnik. Its time you went back to your colouring book and crayons. There's a good boy.
i would go for the fx-8350 but steamroller just around the corner i would hold off also you have haswell comming as well see what the performance of them to are going to be like
