Hi all,
So my system is.
Monitor - AOC Q3279VWFD8 31.5" IPS LED QHD (2560x1440) Freesync 75Hz
CPU - AMD Ryzen 5 3600 Processor
MOBO - MSI B450M Mortar MAX
RAM - Team Group Vulcan T-Force (2x8GB) DDR4 3200MHz
GPU - Powercolor Radeon RX 5700 XT Dual Fan 8GB GDDR6
PSU - Bitfenix Formula Series 550W 80 Plus Gold
SSD - WD Blue 3D NAND 500GB M.2 2280
Case - Kolink Citadel Micro-ATX
I've been experiencing the black screens loading up and even two solid hours of gaming in various games.
So, building this new rig was fun and had no problems with the build or installation of WIN 10 x64, however it would seem I'm now having issues, but if I'm honest it's definitely GPU/GPU drivers.
When I had set the system up, the only two options I had changed in the BIOS settings were, turn on gaming mode and select 3200 speed for my RAM, I did and do still have the BIOS drivers from MSI's support download section, I'm still undecided if those BIOS drivers will make any difference at all if they will then please mention as I'll flash the BIOS later, also if there are any other settings I should change in my BIOS, I'm all ears.
The GPU drivers I'm using are the 20.1.1 and settings are all off and standard as I was hoping that would help.
If there is a way to fix the issue with rolling back, using safe mode, not sure what DDU is but I'm a quick learner.
Thank you for reading.
So my system is.
