Some Quick Advice Needed
19 May 2004
Horsham, West Sussex
Hi,
Putting together a shopping list for an 'under the telly' gaming PC in a Siverstone Grandia GD04 HTPC case.
The main components are
i5-4690K (TDP=85W)
GTX960 (TDP=120W)
Other than that there is the MoBo, possibly a DVD drive and an SDD
I was planning on playing it safe and putting a 600W PSU in there - or should I go with something smaller.
Of the 600W PSUs I'm looking at a Corsair and a Seasonic
https://www.overclockers.co.uk/showproduct.php?prodid=CA-117-CS
https://www.overclockers.co.uk/showproduct.php?prodid=CA-052-SS
Of those two which if any is the best.
Also should I be going for something smaller (a 500 or even a 400).
Many thanks,
Nigel
Seasonic > Corsair.
You can get away with less power such as 500'ish as the 960 sips very little power.
Seasonic > Corsair.
Thanks,
So you would say the Seasonic - is that because they are better PSUs or because it is fully modular whereas the Corsair is semi-modular.
Also is there any benefit in going down to a 500W.
Cheers,
Nigel
The Corsair has flat cables (apart from the main motherboard cable).
Is that good or just a gimmick?
Would going for a 500W be a better option.
Are there any alternatives up to the £60ish mark that you would rate above the two I have listed.
Cheers,
Nigel
Neither, the Corsair has poor quality internals and the Seasonic is noisey. Take a look at the EVGA Supernova GS650 which is on offer at the moment. It's a gold rated fully modular Seasonic built unit and has a 5 year warranty. Be quick though as it comes off this week only later this morning.
There is a review here.
That Superflower has no modular cables at all.
