Some re-spec help needed quick!
18 Aug 2004
Newcastle,UK
Just ordered
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte P67A-UD3-B3 Intel P67 Chipset (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION **
OCZ StealthXStream 2 600W Power Supply [OCZ600SXS2]
Razer DeathAdder Respawn 3500dpi Xtreme Precision Gaming Mouse - Retail (£37.49)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Coolermaster Elite 430 Windowed Case - Black
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK)
Steelseries QcK+ Gaming Mouse Pad (63003) £11.98
It's a long story ordered it awhile ago different spec but the motherboard wasn't in stock I need to lose £103.3, I can lose the mouse and pref keep the mat if someone could paste it the above format would be much appreciated!
I'm on my phone as this needs done today :(
Much appreciated
I was going to make some suggestions but you've pretty much gone for the lowest cost components possible. Anyone else want to take this one?
you could save about £10 by changing the hardrive to this
Samsung SpinPoint F4 320GB SATA-II 16MB Cache - OEM
Personally would rather spend the extra tenner for more than twice the capacity
If your not likely to do any overclocking you could save some money there, by changing the motherboard to a H67, and then change CPU.
But again i wouldnt want to do this
