Some simple flash help please.
18 Oct 2002
http://www.peterlik.com/
See the way when you load that flash site it loads centralised. When i create a 800x600 site for low end users, it loads in the top left corner of IE if viewed at a higher resolution.
Is there an action, or something that allows it to load in the middle and shrink or enlarge the outer black area accordingly.
thanks
just got in and i'm about to have some food (rushed read/post) not sure if i got what you mean but... here's some code i just ripped from one of my projects.
Code:
<div align="center">
  <center>
<table border="0" cellpadding="0" cellspacing="0" width="100%" id="blahTemp01" height="100%" style="border-collapse: collapse">
  <tr>
    <td width="100%" align="center">
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="800" height="512" id="autoplay_root" align="middle">
<param name="allowScriptAccess" value="sameDomain" />
<param name="movie" value="autoplay_root.swf" />
<param name="loop" value="false" />
<param name="menu" value="false" />
<param name="quality" value="best" />
<param name="scale" value="noscale" />
<param name="bgcolor" value="#000000" />
<embed src="autoplay_root.swf" loop="false" menu="false" quality="best" scale="noscale" bgcolor="#000000" width="800" height="512" name="autoplay_root" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
</object>
  </tr>
</table>
  </center>
</div>
any good to you?
Havent got my head totally round action scripts yet so, maybe, maybe not.
Though there may have been a script assist function that allowed flash to be centralised in a IE window, rather than defaulting to the left, as i am not creating a flash piece to fit into a website, but but a website totally created by flash, and exported to a html file.
I know a small amount of html so that looks usefull, basic alignment etc
I shall have to look in to it
thanks.
