Some spec help
27 Nov 2011
Edinburgh, UK
This is my current spec;
I7 2600 3.4GHz
Asus P8H61-M LE/USB3
4gb Corsair XMS3
Sapphire radeon 5830HD 1gb
Corsair 500watt power supply
Maxtor sata 2 500gb main drive
I'm looking at getting a few upgrades soon and I've currently decided on a crucial M4 SSD and 2x4gb corsair xms3.
For Xmas I'm gonna ask for some stuff so I'd like to know of a decent modular power supply for under £100
And where do folk get the braiding kits? I really wanna do some cool braiding
Also Gonna upgrade the case, graphics card and mobo next year, what cases are good for cable management again for say £80-£100 really like White cases (600t)
Thanks!
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-LA&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-BQ&groupid=701&catid=123&subcat=
i would pick from one of those depends on the power you want. and about the braiding i cannot say because its from an outside retailer and dont wanna get banned sorry
if you want full moduler you will have to pay abit more
http://www.overclockers.co.uk/showproduct.php?prodid=CA-052-OC&groupid=701&catid=123&subcat=
i have a cm 690 case and the cable manage ment is great i hear the 400/500r is a very good case to
I wouldn't pick from the 3 choices personally ;)
also there is no need for 700w+ for the ops system unless planning on getting the 590/6990 or next gen equivalent as any single card(as the board can't do sli/xfire) wouldn't require so much power a good 500-600w will be plenty.
