- 21 May 2007
The big thing stopping me from getting comfy with ubuntu is that I cannot seem to get mplayer to work.
I get this.........
apt-get install mplayer mencoder
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mencoder: Depends: libmad0 (>= 0.15.1b) but it is not installable
Depends: libmpcdec3 but it is not installable
Depends: libungif4g (>= 4.1.4) but it is not installable
mplayer: Depends: libartsc0 (>= 1.5.0-1) but it is not installable
Depends: libaudio2 but it is not installable
Depends: libpulse0 but it is not installable
Depends: libxvmc1 but it is not installable
E: Broken packages
And this..........
apt-get install w32codecs
Package w32codecs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package w32codecs has no installation candidate
This is after adding some other repositories mentioned in an mplayer how-to on the ubuntu fora. (assuming such changes are persistent).
I tried vlc, after learning it had keybinds in ubuntu (the default gentoo config is devoid of these, making it either useless, or a whole load of work).
apt-get install vlc
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
vlc: Depends: vlc-nox (= 0.8.6.release.c-0ubuntu5) but it is not going to be installed
Depends: libsdl-image1.2 (>= 1.2.5) but it is not installable
Depends: ttf-dejavu but it is not installable
E: Broken packages
In fact, so far the only thing I managed to install was gwhere ( a great little catalogger, that gentoo removed from portage in a fit of pique....it was the only program that came to mind that didn't throw an error).
One other thing (for now), since I changed KVM, ubuntu has redetected my monitor, wrongly, and when I configure it with the little applet, despite saying "keep configuration", it doesn't, and goes back to 800x600 on "plug and play", even after re-enabling the right gfx drivers.
If I just hand hack the xorg.conf, is their auto detect going to b*gger it all up again on next boot?
I'll confess I've not got too deeply into the documentation, but I'm working on the principle that this is Linux for winlusers and that I've got 7 years of Mandrake, Gentoo, Red Hat and LFS under me belt.
Gutsy Gibbon BTW
I get this.........
E: Broken packages
And this..........
apt-get install vlc
E: Broken packages
Gutsy Gibbon BTW
