- 18 Oct 2002
I’ve recently purchased and built a new PC that I am having some serious and strange problems with. Its an Asus P5E3, with aq6600, 4gb of DDR3 memory and numerous hard drives. I used a fresh installation of Windows for the machine.
A day or so after the fresh installation, I started experiencing problems with one of the drives on the machine (a 1tb SATA Samsung).
I was getting the following errors:-
- An error was detected on device \Device\Harddisk8\D during a paging operation. (warning, source:disk, code 51)
- The system failed to flush data to the transaction log. Corruption may occur. (warning, course:ftdisk, code 57)
- {Delayed Write Failed} Windows was unable to save all the data for the file . The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere. (warning, source:ntfs, code 50)
This happened many, many times – and was presumed to be the fault of the hard drive itself. I struggled to get off the drive and backed up on other locations on my computer. Just when I had started to give up hope, I tried the drive in an external USB enclosure. Low and behold, it worked fine – and I was able to salvage all the data from it.
Everything was fine and dandy for a while. Then, yesterday evening a 400gb ATA Maxtor drive started to experience the same issues. Numerous code 51s, 57s and 50s. As with before, the drive seemed to function normally using an external enclosure.
Last nigh was the last straw. One of my new 1.5tb SATA drives displayed the same issues, with the event viewer flooded by another deluge of warnings and errors. I also noticed these errors (they might very well have happened during the previous faults too):-
- The driver detected a controller error on \Device\Harddisk2\D (error, sorce:disk, code 11)
- A parity error was detected on \Device\Ide\IdePort1 (error, source:atapi, code 5).
Thanks in advance to anyone that can shed any light on these issues.
