some websites not loading properly
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
I try to get onto a website like www.wiggle.co.uk, and in internet explorer, Firefix and Opera it wont load :confused:, the confusing thing is, it loads fine in the crappy AOL9 browser, I have no software firewall and have tried another route and its still the same, any ideas? :confused:
try clearing the cache maybe
That wont help since it does it in every OS on my PC, my other computer and with another router it does it.
My download speeds are **** too, everything to do with the internet outside the crappy AOL browser seems crap, I dont get whats going on, was fine at first, some days you get some websites that dont work, like gamespot, that did not work apart from in the AOL browser, seems to work now but its random with some sites. The only thing outside the AOL browser that usually is working fine and has good speeds is usenet.
Actually, wiggle does load through the ip, but images dont load :confused:
It should be 1400 for AOL.
If the IP works, and the name doesn't, it sounds like an issue with your DNS servers.
Sounds like a dns issue, you could try clearing the cache on each machine and then rebooting your modem, that might help.
ipconfig/flushdns on each machine
I've re installed windows and I have tried multiple different router/modems.
I had the same issue when i was with aol i could'nt load up www.bethere.co.uk and some other sites tried changing the dns server to one that i found on the aol support forums and it worked after that might, it be worth trying a few different dns servers ip's. just an idea
