OcUK Staff
- 26 Nov 2014
- Stoke
Launching today, we have a bunch of new Raijintek products for your consideration. First up we have the Coeus TC Evo & Elite, a pair of new chassis designs, with aluminium construction and tempered glass exteriors. The Elite is Micro-ATX, with the Evo an Midi-Tower equivalent. Both cases feature front, roof and side panels made of tempered glass. The Elite comes with 3 x 120mm White LED Ring Fans installed, with up to 280mm radiators supported on the front & top. The Evo comes with 4 x 120mm White LED ring fans installed, with up to 360mm radiators on the front and 280mm radiators at the top. Both cases can support 350mm VGA cards and come with a USB3.0 Type C on the front I/O. These will be in stock within 7-10 days.
Next, we have the Paean M, which is a Micro-ATX version of the original Paean chassis. It includes many of the original Paeans features, such as an aluminium construction and tempered glass side panels. It can take an ATX PSU and supports a 280mm radiator as standard, with support for a 430mm VGA card. Stock will be arriving in 7-10 days.
Finally, we have the Paxx PCIe 16x Riser Card Cable + PCI Adapter Kit. This allows you to vertically mount a graphics card in most conventional tower cases. The cable supplied is the full speed Gen 3 model as to be expected, and comes with the adapters to fit the graphics card securely within your chassis. Once again, stock will be arriving in 7-10 days.
Raijintek Coeus Elite TC Aluminium Micro-ATX Case - Black Tempered Glass @ £122.99 inc VAT
The Coeus Elite TC from Raijintek represents a premium transparent Micro-ATX tower, one which makes for a drastic departure from the previous Raijintek cases and offers a more premium aesthetic.
Only £122.99 inc VAT.
ORDER NOW
Raijintek Coeus Evo TC Aluminium Midi Tower Case - Black Tempered Glass @ £134.99 inc VAT
The Coeus Evo TC from Raijintek is an almost completely transparent midi tower which stands apart from previous Raijintek cases and makes for a much more elegant appearance.
Only £134.99 inc VAT.
ORDER NOW
Raijintek Paean M Micro-ATX Benchtable/Showcase - Black Window @ £79.99 inc VAT
he PAEAN M is the Micro ATX / Mini-ITX version of the innovative show case from Raijintek.
Only £79.99 inc VAT.
ORDER NOW
Raijintek PAXX PCIe 16x Riser Card Cable + PCI Slot Adapter @ £82.99 inc VAT
With the PAXX conversion kit consisting of a riser card extender cable and a special PCI slot bracket, a graphics card can be installed vertically in almost all tower-style cases.
Only £82.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
