someone help me with fps??
29 Jun 2004
i have a 260gtx.
now to get 60fps in left for dead i have set the resolution at 1600 x 1024 but my max res is at 1920 x 1200. it does run smoother at the lower rate and the fps stay on 60. is this ok from a gaming point of view? thanks
I am pretty sure the 260 should be able to push at the very least 60fps even at 1920x1200, I know my 4890 does on both L4D and L4D2.
You do want to try and get 60 fps though for sure, disable vertical sync and you might find that even at a higher resolution you are getting smoother gameplay, are you playing on 100% maximum settings? Try lowering AA a little, but I would say play at 1920x1200 if possible.
