Hi
I have read numerous "how to" guides and on overclocking in general, but for some reason - I just don't get it, pure and simple
Even the most simple of guides, doesn't get me through it at all.
I followed this guide posted by monstermunch on the motherboards sub-forum, but again, I got half way through and got lost.
Would someone be so kind, as to do an IDIOTS guide on how to overclock the following system
C2D 6300
Gigabyte DS3P (revision 2 i believe)
GeIL 2GB PC6400C4 800MHz Ultra Low Latency
The cooler should do a ok job - I dont want to push it to the max anyways, up to something like 2.8 and I'll be stoked.
Now - I used the "how to" below , but around number 9 I was lost. The options in my motherboard doesnt EXACTLY say VDIMM etc - so I'm at a loss.
If it doesnt say exactly what my mobo's option says - I'll start to panick
Anyone here kind enough to help me out?
Edit: or is it just worth I only use Easytune 5 ?
C2D 6300
Code:
Clocking
1. Make sure that you have the latest chipset drivers and flash the board to the most recent bios version
2. On the main bios screen press Ctrl+F1 to open the advanced options within the menus
3. In the Advanced Bios Features Menu, Disable all of the following: CPU Enhanced Halt (C1E), CPU Thermal Monitor 2(TM2), CPU EIST Function
4. In the PC Health Status menu, set the FAN Speed Control Method to "Legacy" & FAN Speed Control Mode to "PWM" to maintain highest speed
5. Go into the MB Intelligent Tweaker (MIT) menu at the bottom of the page, set the System voltage control to "Manual"
6. These boards have a default VDIMM of 1.8v, set the VDIMM to co-ordinate with your ram. The Geil I have is specced as 2.1v so I have mine set to +0.3v
7. Set the MCH Voltage to +0.1v
8. Set the FSB Voltage to +0.1v
9. Set the VCORE to 1.45v - Please be aware that this will increase temps!
10. Set the CPU Host Clock Control to "Enable"
11. Set the System Memory Multiplier to "2x"
12. You're set to go, just increase the System bus Frequency to Overclock
13. I would reccommend that you use Intels TAT to monitor temps
