Someone please help with my first build (stuck)
2 Aug 2011
Hi,
i purchased all my parts from here and this is my build:
Now this is my first ever build, fist ever time inside a computer case infact.
Ive done the following in this order:
1) Installed PSU
2) Installed RAM
3) Installed CPU + Cooler
4) Placed in I/O plate + motherboard standoffs
5) Installed GPU
6) Connected front panel pins (correctly i think) , USB, HD-AUDIO
So now i think i just need to power everything up, but there are so many wires im a little confused:
Like these 3 pin connectors, where do i connect these?
This is a pic of my progress so far:
Im a little worried about static damage as ive had no protection and have been working on a pine desk.
Also, i cant test to even see if it works as im still waiting for my monitor from OC.
Take those things out of the back of the graphics card.
Pick up the wires on the PSU and you will find a pair of 6+2pin connectors, stick them in.
They are like these,
I think there may be a vent underneath the PSU, you might want to flip it over in that case as it will draw in fresh air.
There should be four in total, just leave the 2pin bits hanging if the card only takes two 6pin inputs.
Turn the PSU over also if theres a vent underneath.
Attach a 8pin (2X 4pin) ATX power cable to near the CPU on the motherboard.
Plug the 24pin in.
Plug the 24pin in.
ah thanks, its just a matter of waiting for my monitor now
just hope it works :(
