Someone please put mind at ease
23 May 2006
I am a larger man at over 6"2 and the wrong side of 20st.
I just bagged a noble epic gaming chair on special offer based on the overclockers bumpf saying it supports up to 180kg.
However I just read a review of it and whilst they were very positive of it their only really negative was it was not suitable for larger gamers with a weight.limit of 120kg
So which is it?
I will have to cancel if it is only 120kg
Thanks
https://www.techpowerup.com/reviews/noblechairs/Gaming_Chair/
Hi thanks for your reply... Overclockers however confirmed it IS rated to 180kg. i contacted noblechairs and they also confirmed that whilst they only advertise it to 120kg, the gas supports - which is the limiting factor apparently - is rated to 180kg load.
either way i will use it, and check it out fully just before the warranty expires and if there is any problem with it, return it and attach the confirmation from ocuk that it is ok for 180kg ;)
I asked noblechairs on facebook a while ago, and they said that 180kg is the max limit they tested, they officially claim that 150kg is the limit.
All a bit confusing.
