Someone sanity check me please
28 Dec 2003
So I'm moving from a Corsair Type 3 to a Type 4 PSU.
Can someone please sanity check me that the only difference with the cables between types 3 & 4 is the 24-pin ATX?
I have a set of custom Cablemod cables I want to re-use and am thinking I can use all except the 24-pin?
What I don't understand is why the non-24-pin connections appear different on these two pages:
On closer inspection, it seems that, for all cables other than the ATX 24-pin, the cables are compatible, in that the right voltages are on the right pins, but the actual wiring appears different.
So clearly they are compatible but I'm wondering why Corsair decided to rearrange the wiring and whether this means that "genuine" Type 4 cables are better in same way than older type 3, even though they'd both work.
This might answer your question:
Gen 3 uses a nylon sleeve and there's heatshrink where the sleeve meets the connector. Gen 4 uses paracord and there is no heatshrink on the ends of the sleeves.
Type 4 cables have an additional +12V, +5V and ground sense. Type 3 only has the +3.3V sense.
