- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Well following on from the thread in case central. I can now announce my news. This is one for the true PC water cooling connoisseurs. I'm sure RJKONEILL will be here soon to help with your actual watercooling needs for your build
XSPC H1 Enthusiast Cube Case - Black @ £349.99 inc VAT
The XSPC enclosures H1 and H2 were specially designed for High-End PCs!
The used material, aluminium, already says much about the quality of these excellent enclosures: Very rigid, lightweight and robust thanks to the surface finish on these enclosures. THe design offers plenty of space for radiators, pumps and tubing, allowing all-internal installation of a high-end water cooling system without the need to cut or drill into the enclosure. Multiple windows allow view into the inside of the system to properly present your water cooling system.
Many ingenious little features can be seen here in the English illustrated mounting manual
- Technical specifications:
- Dimensions (DxWxH): 619.3 x 475.6 x 529.8mm
- Colour: Matte black
- Material: Brushed aluminium
- Fan openings: 16x120mm
- 5x Triple 120mm
- 1x Single 120mm
Drive bays:
- 8x 5.25" drive bays
- 5x HDD bay (up to 10 with optional HDD cage)
- 1x SSD bay (Up to 10 with optional drive bays)
2 Acrylic windows
Extent of delivery:
- 1x XSPC H1 Cube Case
- Mounting screws (6 - 32UNC)
NB: There is a lead time of 1 week typically. May be higher during busy periods.
Only £349.99 inc VAT.
ORDER NOW
XSPC H2 Enthusiast Tower Case - Black @ £349.99 inc VAT
- Dimensions (DxWxH): 618.9 x 246.6 x 696.8mm
- Fan openings: 6x120mm
- 1x Quad 120mm
- 2x Single 120mm
- Drive bays:
- 3x HDD bay (up to 6 with optional HDD cage)
- 1x SSD bay (Up to 6 with optional drive bays)
- 1 Acrylic window
- Extent of delivery:
- 1x XSPC H2 Tower case
ORDER NOW
- 5x Triple 120mm
- 1x Single 120mm
Drive bays:
2 Acrylic windows
Extent of delivery:
ORDER NOW
- 1x Quad 120mm
- 2x Single 120mm
- Drive bays:
- 1 Acrylic window
ORDER NOW
