Something DIY HiFi: Valve Sigma Delta DAC (no silicon)
13 Jan 2003
I've been looking at DACs, with a headphone amp for a while - although the new koi pond is taking the time, this is on my list of 'make something'.
It's impressive because it takes digital audio and outputs analogue without using a DAC chip. Instead it uses valves to implement a DAC taking in PCM or DCD depending on the implementation. The natural extension is to then add a tube headphone amp stage. Mine are 55ohm so this is a challenge given valves like high ohm), an extension would be to drive some sensitive desktop speakers.
The main build threads are here: https://www.diyaudio.com/forums/digital-line-level/308860-valve-dac-linear-audio-volume-13-a.html
Windows needs some drivers for higher-quality DSD, OSX has PCM output inbuilt but the options in the build is to use a beaglebone board to act as a music server. However I'd like to make the system take OSX output so it can be used with OSX apps.
