- 19 Aug 2011
I'm wondering why this is? CPU-Z says with default values Core Voltage 1.248v when Idle, and 1.216v when under full load running Prime95 for such a low Turbo Ratio? However the value next to Offset Mode in BIOS says 1.080v and when I use this value in Manual mode everything runs fine, but a Temp difference of -10c.
Should the voltage acctually be reading as 1.248v under optimized default values (i.e i5 3570k 3.40GHz Everything on Auto etc.. or is something not right?
