Something Similar To Macbook Air
14 Oct 2009
UK
Hi Guys,
I was looking at a few laptops today and i couldnt help but notice the Macbook Air but the price put me off a bit.
So is there anything that is comparable to the Macbook Air in terms of weight e.t.c that is cheaper than the Macbook ??
Thanks Guys
you've got all the culv based laptops coming out although in my opinion, spec for spec the macbook air is pretty good value if you want a thin laptop while still getting good performance
You're not going to get one quite as thin but something like the new Dell 13z may be worth a look.
£480 gets you:
1.3ghz dual core CULV, dedicated graphics, 13.3" LED backlit LCD, Windows 7, 320gb HD and 3GB ram.
