" Something Went Wrong And Your Pin Isn't Available "
17 Feb 2009
Fresh install of windows a couple of weeks back ( W11 )
And sometimes after going to the lockscreen after logging out it will say " Something Went Wrong And Your Pin Isn't Available " when I try to log in
Any idea for a permanent fix ? Usually I restart the PC then it works fine
thanks
You could try delete or Rename the NGC folder
But I wouldn't mess around
With that stuff
Until I had a full backup
It's possible to get 30 day lockout of Microsoft account
Got locked out once
Using the I forgot option etc
On log in screen didn't work some we can't contact
Microsoft right now error
Forgot exactly what it said
Safest since you can actually log in
Probably just go to settings
And redo/change/reset your pin
