Something wrong with G3258? Firestrike Benchmark
19 Sep 2016
Jensen's Leather Jacket
I recently built a budget built with the following components
CPU: Pentium G3258 @ 4.0Ghz
CPU Cooler: Rajentek Aidos
GPU: Powercolor R9 280X
MB: MSI H81m-P33
RAM: 8Gb DDR3 Corsair (clocked at 1333 because of the G3258 - capable of 1600Mhz)
Storage: 120GB SSD / 500GB HDD
Case: Corsair Carbide 88R + 3 x 120mm Fans
PSU: EVGA 500W 80+
I initially used the 3D mark Demo before and during setting up the OC on the system. I eventually settled on the below and as you can see from the initial and final scores there was a good increase.
Temps are stable. the GPU reaches a max of 70°C and the CPU a max of around 50°C so im very happy with that.
Something has happened to the PC and I have no idea what.
All of a sudden my Physics score has dropped off to much less than even what I was getting with the base clocks.
The Graphics scores remain consistent with the last image I posted (About 9400-9500) but the Physics score has dropped off to below 1800 (about 5-6fps average)
Now, I know that the physics test is mainly CPU bound so I thought I might be experiencing thermal throttling of the cores, and I bought the full version of 3d Mark this week to be able to easily monitor everything that is going on.
The result was just as I had prevously seen. about 50°C through out the test. and the clock speed never dips below the 4Ghz - so its not throttling.
Long story short is I have no idea what to look out for. The CPU usage in task manager is minimal - below 5% before I run the test and there are no programs gobbling ram in the backround as its a fresh install of Windows 7 Pro.
Does anyone have anything I can look into?
The only 2 things I have done is added braided GPU Cables and tried out MSi's OC Genie tool in the MB Bios which I then turned off and reset my multiplier to 40 to get me back to a manually set up 4Ghz.
What would cause a CPU to suddenly half its physics scores?
The first things I would do would be to completely re-dial in the overclock manually to make sure to eliminate any crapwork done by OCD genie and also to go back to your stock GPU cables. Not that that's a likely cause but you want to eliminate possible culprits one at a time.
If the issue persists at that point, re-install your CPU and cooler. After that try a different power supply.
Any power surges or thunderstorms recently?
