I was previously running at 625/1600/1024 settings in Rivatuner 2.05 for my 8800GTX. I then read that boosting the Shader gives the biggest performance increase overall and if overclocking you should start with that. So I reset the clocks to defaults and then clocked the Shader. But I've gone gradually all the way up to the maximum of 2025Mhz. Surely this can't be safe?! I thought such an overclock would be impossible on this card, especially with only the stock fan.
I should note that on my previous overclock settings, pushing the shader to 1625 would cause the system to lockup under stress testing. But at default values it runs fine at 2025...
Someone explain please.
