Hey all, been having a very strange problem over the last few days that i know is hardware related, but i cant for the life of me figure out how to narrow down the cause diagnostically.
System specs are as such:
AMD Piledriver 8350 @ 4.6Ghz 1.4V overclock
Asus Sabertooth 990FX R2.0
Corsair Carbide 540 Case (2 front fans 1 rear and 1foot air clearance all round, (it has its own little table))
Corsair H100 cooler (max temp cpu after a few hours gaming is 48C)
Seasonic G 750W "80 Plus Gold" PSU
Corsair Vengeance Pro Silver 2x4GB DDR3 1866Mhz Dual Channel
(All above components are 9 months old although H100 was a refurbished unit bought at that time)
Other components:
Boot Drive:
OCZ Vertex 3 60GB 2.2 firmware (3+ years old maybe)
Windows 7 - 64bit (100% legit) Though i've never installed any updates other than ones i select manually (about 3 in total, all in relation to the 8350 utilisation)
Storage / Game drive:
Samsung 840 EVO 120GB EXT0BB6Q Firmware (13 Months old)
GPU:
1 x Sapphire 7950 Vapor-x 3GB ram running 13.11 Catalyst drivers (13 Months old)
Now the problem is odd. I'm out of ideas which is why i'm posting here but it started 2 days ago when i'd just installed uplay then remembered i was going swimming so turned PC off, got ready then thought "ah i'll leave watchdogs downloading while im out, probably take 3 or so hours" and when i went to turn it on.. nothing. Nothing as if the power switch was broken and wasnt sending the message.
No fans spun (including PSU fan), no beeps just a single green light on the mobo, not even the power switch light went on.
So immediately i thought it to be a PSU problem. Turned the psu switch off at the back, took the kettle plug out the back and refitted it after 20 seconds, turned it back on.. still nothing but the single green light on the mobo.
Packed it up its original box with all its gubbinz and was planning to RMA it for testing but while driving it too the postoffice i went to a local computer shop (the kind that live off word of mouth but are really good and bend over backwards for you) and they had a voltage tester there so the connected my PSU up, 12V line showed stable (12.2V biggest measurement) and so i decided not to RMA straight away and do some more testing.
Today -
Reinstalled PSU.. reattached all cables, and re-seated jumpers on mobo.. It POST'd, couldnt read boot devices, then shut down after reaching 52 degrees on cpu
(I then facepalmed and attached H100 and HDDs to PSU)
Then it worked flawlessly, booted fine, it had even saved my overclock settings (4.6Ghz) so left it all alone, put it down to a loose jumper and carried on regardless.
Then around 2 hours ago while having my first big go at watchdogs.. it blue screens (its first ever) and when i try to power it up again.. nothing... same as before, so power, no fans spinning... nothing but the single green light on the mobo.
I go have a bath, come back.. case sides off, finger check all connectors on mobo and HDDs with power cable out.. re-attach and it boots and is stable (hence this post).
So i'm confident its going to happen again because i never found anything that made me go "ahhhhh it was this that was wrong" and to me blue screens mean some piece of hardware is faulty / on its way out.
So im running some HDD diagnostic tools at the moment but incase it dies again i thought i'd throw this post up to ask the Overclocker Oracles for any light they maybe able to shed on this confusing issue.
Thanks for reading, i know i've rambled on here but i felt its best to get as much info out as i could.
Other components:
Boot Drive:
GPU:
Today -
, stripped it down on thursday and soldered new capacitors into it (the old ones were clearly swelled up amnd measured about 10% of the value they should be) and it works fine
" just tried to overclock the fsb a bit and give the core 1.4V again and it gave me the same treatment.
