sonata 2 noisy psu
28 Apr 2007
hi there
just built a new computer using the above case.when i switch it on it emits a high pitched noise.obviously this isn't normal.
is there something i'm missing
martin
lmfao.
The RMA number is a number that you can get from Overclockers if you report a fault item, you send the item back to overclockers with the RMA number made clearly visible, and they will be able to replace it/refund you
mchivers said:
sorry to be a total pleb but what's an rma number
i doubt you are a 'pleb' they were pretty much all given roman citizenship...although i suppose the term stuck as a lower class majority... lol :D
ok i dont know what the hell it stands for... i dont think many people do :D
just email antec customer support, explain the problem, wait for the RMA number, send said PSU away to antec with you P.O.P. and have a new one in working order shortly
