Sonata case modding
11 Oct 2005
Doncaster
as anyone got a Sonata case and modded it in anyway?
put more fans in it etc etc.
Couple more questions regarding this case.
When i bought my Sonata case i set it up myself....the problem is with the front LED lights and the Reset button never worked since i've had it. this was 10 months ago now...and since then i have upgraded my pc parts set up once again and the LED & Reset button still don't work....as anyone else had the same problem with this case? and if so did you fix the problem and how? thanx for any help in this matter.
With the reset button most likely the wire has broken contact with the plug, try re-seating it on the header plug.
The LED could be plugged in the wrong way, or the same as the switch, not properly seated in the header.
The wires sometimes are not made with a proper contact, however this is highly rare and to have it twice in one case would be some seriously bad luck :p
