Sonata II case + Tuniq Tower 120
Permabanned
29 Jun 2007
Benfleet essex
The TT is HUGE, would it fit in the Sonata II case?
I know it just about fits in the Antec 900 case, but dont know about the antec sonata II..
Should just about fit, but the orientation needs to be such that the fan faces the PSU rather than the exhaust.
Mul
I've got one in my Sonata III (which I'm pretty sure has the same internal dimensions as the II) and it fits in the normal orientation*. It may depend on the location of the socket on your mobo. Some have it a little to close to the PSU, so then you'd have to put it in sideways.
FWIW I'm using an EVGA 650i ultra
*edit: by this I mean blowing out the back
