Sonata II Question
15 Oct 2006
Hey guys, when i built my PC i took out the vent thingy that helps take air out from CPU to the bottom part of the case(?) and basically ive lost the screws and i have been recently getting some high temps, even tho this cpu is meant to run like the sun. Would this ventilation really work, and how could i go about getting thescrews ;o.
Temps: 47 - 50 Idle
Load: 54 - 59
Max Temp according to intel 63
MB Temp : 35-40degrees
Fan speed: 2600RPM
using stock heatsink with zalman thermal paste (cant afford a CPU cooler as of yet).
another thing is, i usually have to leave to hinge door open to save a few degrees (if over 60, the fan makes a hell of a noise) so im worried about a dust issue how likely is it dust can get in and damage anything? my room is fairly dusty. Thanks for your help.
