Sonata II - Side Window?
22 Jul 2006
Hi All,
I am bored with my Sonata II again, last time i modded it by cutting a blow hole in it, this time i am wanting to cut the side out and either mesh it or put a window on it so i can make it look nice and show of the internals :)
Would this be possible? It has the clip / security lock thinh on the side? Would i be able to cut round it without making the whole side really weak?
Yeah you could cut around it sure, i window would look good with that bit sticking out anyway, as for the mesh, you do what you wanna do but i would just go with the window for starters, and decide from there what to do, because you can always change it if you want something bigger or better :D about making the side weak, the window with reinforce it anyway once you have made it fully, but by looking at it i'd guess it's a pretty sturdy case anyway :)
