Sonic Tower
1 Nov 2004
Well this is a first for me asking what a ThermalTake product is like but i keep reading good things about the Thermaltake Sonic Tower.
Anybody running one ifso what do you think of it ?.
I love Quiet and this Cooler keeps turning up in silent pc reviews.
Whats the temps like ?
I have also read that this cooler only needs a 120mm fan at 5v to
get a drop in temps close to most pipe coolers that are on the market
due to it's very long pipes and mass amount of cooling fins.
A good aftermarket 120mm fan fits nicely between the two towers, so u dont need to use the supplied bracket. Imo it cools better that way anyway. I have a 3 speed antec 120mm fan in mine, set at 5v, and at stock it idles at 32c and full load about 43c. Overclocked, set the fan to 12v and idles about 33c full load up to 52c. I'm sure that with a conroe temps will be a bit lower as well. We'll see in a couple of weeks time when I get mine.
It's starting to look very tempting.
A few pounds more than a Arctic Cooling Freezer and way cheaper than a
Scythe or Tuniq Tower.
What motherboard u using/going to buy. It is big, i was a bit concerned that it wouldnt fit my DS4 with the motherboard heatpipe cooling, but no probs.
I have one, and I love it. Use it on an [email protected]
Admittedly, I use it with a Delta Exhaust just behind it, but it has to be efficent to keep 5Ghz cool, regardless of CFM passing over it. If it's not transferring the heat to the Fin's, it aint gonna be cool.
