Sonos and existing gear
23 Nov 2014
The Cronx
Hello all
I currently have a play5 and 2 play3 in the kitchen and very happy with it. In the lounge I have a Cambridge Audio Azure 630 i think with the Tv, deck and cd player attached via phono jacks. I have 2 pairs of floorstanding speakers (via speaker wire) attached.
The amp has started to play up, so rather than just replace it Sonos is the way to go if possible.
Assume I know nothing, how do I sonos this system keeping everything bar the ropey amp?
Keep it under £1000 if possible!
Sorry title should be "existing!"
Thanks
It's quite tough to figure out what's best for you actually. The Sonos amp is pretty limiting.
You're probably best getting a standard amp and a Sonos connect (non-amp).
technically you wouldn't need your CD player once you have a Sonos connected. That'll save on inputs. Did you say you have a turntable? I don't think that could connect to the Sonos Amp anyway.
