Although both models are designed to provide high-quality sound, the Sonos Five may have a slight edge due to its bass response and clarity.
Additionally, think about the size and design of the speakers. If you have a large room, the Sonos Five's larger size may be a better option. Conversely, if you're tight on space, the smaller Sonos Era 300 may be preferable. Additionally, the modern design of the Sonos Five may be a good fit for some aesthetics while the more classic look of the Sonos Era 300 could appeal to others.
Finally, take price into consideration. While the Sonos Five is pricier than the Sonos Era 300, it could be worth the investment if you're looking for top-of-the-line sound quality and a more versatile speaker.
To make the best decision, it's a good idea to listen to both speakers in person if possible, and weigh up all the factors mentioned above before making your final choice.
