- 15 Aug 2006
- Leicester UK
Hi All,
I had been using the bundled sound bar that came with my Sony 50w829 but always had it mounted on screws into the front edge of the wooden TV stand because the height of it obscured the picture and IR receiver if it was sat in front of the TV. We’ve just replaced a lot of the furniture including the TV unit with some oak bits and don’t want to screw into it.
The picture starts at 60mm from the surface of the unit which means finding a decent sound bar to fit is proving difficult.
We watch everything through Apple TV so was thinking of putting a Sonos play three in the top spot where a DVD player would normally go.
Two questions:
Has anyone got any other ideas that will fit with what I have?
Would I be able to add 2x Sonos One to give tear surrounds at a later date like you can with the PlayBar and Beam?
Pic of the TV unit:
![](https://thumb.ibb.co/bS6Noe/D08_A7482_C7_B7_4604_B92_F_0_D08891_BD4_C5.jpg)
Two questions:
Pic of the TV unit:
