Sonos sound systems (multi room)
17 Jul 2008
im looking at spending a few hundred pounds for some sort of multi room sound system, im not looking for top audio quality but i do want something that jsut works... are the sonos systems (looking at 2 / 3 room setup) the best option
It might also be remarked that you can get top audio quality out of Sonos (in addition to its undoubted convenience). I plug a Sonos Connect into my HiFi and it delivers.
few hundred pounds and sonos does not compute.
the stuff is expensive, and if your looking at 3 rooms it's going to be very expensive.
it is probably the best option out there though.
